amp and speaker questions
XX95DSMXX
ok well i just got a free amp its a jensen XA2125 and i got the 4-Ohm version of the Kicker CompVR DVC now what i need to know is how should i wire the subs (series/parallel) and also how i should hook it up to the amp (bridged or not)...the reason i dont know the answers to the questions is i do not undersand how to figure out ohm loads...thanxs for any help
here are some details so ya dont have to look for amp info
OUTPUT SECTION Number of Channels 2
Peak Power Per Channel @ 4 ohm 150
RMS Power Per Channel @ 4 ohm 75
Peak Power Per Channel @ 2 ohm 200
RMS Power Per Channel @ 2 ohm 100
RMS Power Bridged @ 4 ohm 400
Power Bridged @ 4 ohm 200
XA2125 Features
MOSFET Power Supply
Bi-polar Output Transistors
2 ohm Stable (Stereo Operation)
Tri-Mode Operation Bridgeable Operation
Variable High Pass Crossover (40-240Hz)
Variable Low Pass Crossover (40-240Hz)
12dB/Octave Crossover Slope
6dB Fixed Bass Boost @ 45Hz
High Level Inputs
Input Level Control(s)
Pass Through RCA Outputs
Extruded Aluminum Heatsink
Top Mounted Controls
Thermal/Short Circuit Protection
Power LED Indicator
Protect LED Indicator
Illuminated JENSEN Logo
now the stuff in bold red is what i would like to obtain but i need help figuring out how to wire the subs to get the 4 ohms
Is each coil 4ohm? If so, wire them like this:
XX95DSMXX
XX95DSMXX
mannington wv
squeak9798
