Amp and fuse holder question
I don't know what that means. Im using a power acoustik a3000db and a rockford fosgate 2 gauge wire. We're about to hook it up, I just want to know if it will work.
I have my a3000db wired at 2 ohms, and I have a 150 amp fuse on it, been going strong for months without it popping....
You should be fine, hook it up, and let it loose.
Ok so my friend hooked up the 150 amp fuse and as soon as he touched him battery the fuse blew again...hes pissed out of his mind and said hes gonna drive his car off a bridge. Whats the problem?? I said it might be the battry and told him to take it into schucks to get it looked at.
The only thing that can explain that is a short in the wiring...
Somwhere in this set up, the power wire is connecting directly with the ground, find that point and eliminate it...
xJTmoney5T
xJTmoney5T
Seattle, WA
45auto
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
