Amp and Cap Wiring Help
Spacehippy42
MT
Alright, I'm fairly new to car stereo's, but I've installed a few simple ones, so I'm not completely in the dark about it.... I was just wondering, can I install two amps ( 1 powering my subs, and the second powering 6x9's) off of one cap... Or does that just not work..... I was thinking, I could run one power cable from the battery to the cap, then off of the cap have a distribution block going to the two amps.... ( the cap is large enough for the wattage of both amps, but is this okay to do, or is that not good?? If not, what do I need to do to make this work? Any help or advice would be much appritiated, thanks.........
everone is gonna flame you and what not saying "Dont get a cap." I promise you will soon read the following phrases or some what similar:
- Get a battery instead mainee!!11!11
- That is just a band-aid to cover up your problem, it doesnt fix it.
- Your money would be better spent elsewhere.
The reason I can predict the EXACT statement like a dozen of douche-bags are about to give you is because they are conformists, and got these phrases from reading other posts and then just repeat it without actually even trying it or not. Im not saying that caps are worth having, I really dont know. Im just letting you know that 95% of the people who are going to tell you the 3 statements above havent tried caps cuz they read that statement when they asked, and now swear by it without even really knowing. Kinda makes me sick. //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Ohm's Law makes you sick?
Hope you don't want to be an engineer.
Well, like I said I'm new to the dual amp and cap idea, so can someone just explain to me how I can hook up two amps with a cap to 2 12" kicker comp subs ? and how to do it correctly, and if there are any negative sides to it, maybe explain why they are negative.... thanks again, any advice and help is much appritiated!!!
alright, that's how i figured it would be done, but I wanted to get some advice from someone that is a little more experienced... thanks
you apparently havent seen the eleventy billion threads about caps and links to a lengthy read on WHY they are worthless...
Alright MTLHEAD, if you know so much about Caps, could you save me some time and let me know why they're so worthless.... I'm not saying they aren't, but I just don't know one way from the other about them, so maybe if you could fill me in....thanks
Spacehippy42
Spacehippy42
MT
05gliguy
NorthFramingham
    Jun 30, 2026
