Amp @ 4ohms for an Eclipse 8200?
ultimate157
Engineering Student
I just bought an eclipse 8200. It will be put into a 1^3ft box, sealed. I am wondering about it's power handling though.
It says that RMS is around 650w, however the peak is 2000w. I've never seen a sub with rms vs peak by a factor of 3x.
What is an amplifier, monoblock, that would be a good match to this sub? Preferably with higher output @ 2 ohms should I want to upgrade later.
Budget: Under $200.
Not many amps put out that much power at 4 ohms for under $200. You could try to snag a PG x600.1 which puts out the same power at all loads.
Should always know what amp you get before you buy a subwoofer. Is the 8200 a single or dual voice coil?
Here are the specs
800 watts RMS x 1 in bridged mode
400 watts RMS x 2 at 2 ohms
200 watts RMS x 2 at 4 ohms
variable front and rear high- and low-pass filters (50-5000 Hz at 12dB/octave)
CEA-2006 compliant
multiplier x10 switch converts filters to variable from 500 to 5,000 Hz
LED clipping indicators
preamp-level inputs and outputs
front end defeat bypasses gain and crossover controls
fuse rating: 30A x 3
4-gauge power and ground leads
11-7/16"W x 2-3/8"H x 17"D
bridging 2 channel amps almost always will only bridge at 4 ohms, there are a lot of exceptions.
ultimate157
Engineering Student
ultimate157
Worcester, ma
99StangGt
