American Bass XD3000D
One of the best amps ive ever had. I bought it for 375 local sold it for 350 kid blew it with stock shitty electrical, then threw it away I am pissed. It was fine for me never got warm could push my subs hard and keep them from stinking = no clipping. that was 3 years ago .
it has been replaced by chris at dbr. thanks for the input and looking for more. its it still a good amp for the money or anything else out there
XD-3000 Amplifier Specifications:
Power Output
RMS @ 4 Ohm: 700W x 1 Ch.
RMS @ 2 Ohm: 1300W x 1 Ch.
RMS @ 1 Ohm: 2500W x 1 Ch.
RMS @ 1 Ohm: 4000W x 1 Ch @18v
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
My XD2000's are rated at 2000 wRMS @ 14.4v
I don't have what it takes to bench them myself, but several reviews have shown that they put out between 1400-1600 wRMS.
Although I don't have any personal experience with the XD3000's - if they are built similarly, you can expect 70-80% of rated. I can't tell you this for sure, but I can definitely tell you that they are well built, reliable, and efficient amps.
ltr450racer690
ltr450racer690
west laffy
arnold8819
