american bass ph4100
NuckinFutz
Cosmetically 9/10 light scratches on mounting feet
Mechanically 10/10 only used for about a month, gain was set with dd-1
80 shipped
On me
American bass PH-4100 FR Mini Phantom Series Series 4-Channel Car Amplifier
RMS power Rating (14.4V):
4 ohms: 100 watts x 4 chan.
2 ohms: 200 watts x 4 chan.
Max power output: 400 watts x 4 chan.
MOSFET power supply with high grade switching devices
LED power/protect indicators
Designed to fit into restrictive or limited spaces while still delivering staggering amounts of power
Ultra efficient Nano Technology power supplies and endless possible installation scenarios
4-Channel operation
Extreme power in a small footprint
Ultimate mounting flexibility (stackable, line array, side mount)
Mill Spec double sided PCB with SMD parts
Built-In noise reduction circuitry
Heavy duty aluminum alloy heatsink are anodized in a Raven Black finish for extreme heat dissipation
3-Way protection circuitry (short circuit, overheating and Low Voltage)
Chrome-plated rca level inputs
Chrome-plated screw terminals
Adjustable high-pass filter (50-750 Hz, 24 dB/octave)
Adjustable low-pass filter (50-750 Hz, 24 dB/octave)
Subsonic Filter (50-750 Hz, 24 dB/octave)
Frequency response: 15-25,000 Hz
THD (Total Harmonic Distortion):
Signal-to-Noise Ratio: >80 dB
Max Voltage: 15V
Max rca Voltage: 5V
Dimensions: 10"L x 5-1/2"W x 2-1/8"H
__________________
80 shipped
On me
Your PM's are full sir.
NuckinFutz
NuckinFutz
Shreveport, La
Spooney
