American bass 1100.1
cal
A.B. vfl 1100.1
american bass 1100.1 12v version
2. Specs:
1 ohm Stable Class D Mono Block Amplifier
Low Level Input and Output
Frequency Response: 20Hz ~ 350Hz
Input Level: 0.2V ~ 6V
Variable Subsonic: 10Hz ~ 50Hz
Variable Low Pass Filter: 35Hz ~ 250Hz
Variable Bass Boost: 0~ 9dB at 45Hz
Remote Gain Controller
Two amplifier Linkable Connector and Controller
12,500 Watts RMS
Width: 9.5"
Height: 2.25"
Length: 36"
amp is used but clean and fully working , the amp was repaired by previous owner due to water causing fets to blow . from what i was told all fets on power supply side were replaced to match and gate resistors were replaced as needed . i tested the amp and its fully working i also had a shop bench test the amp and they confirmed amp has been repaired to factory specs and @ the time of inspection needed a new fan and that has been replaced . amp is currently installed and runs with no issues only reason im selling is i have 2 ddzse to play with
1450 .00 shipped in the u.s.
no trades but willing to do a payment plan
Dammmmmmmm just what I need for a blow thru
yep . and forgot to mention i can do a payment plan
---------- Post added at 02:53 PM ---------- Previous post was at 02:52 PM ----------
So what kind of electrical do you need to power this beast? Just curious
i have a 300 amp alt plus 5 group 31 and it does just fine
cal
cal
cal
