A.B. VFL 1000.1
amp is used and very clean . no isues works as it should . please see pics for cosmetics i dot use that number rating because we all know we rate stuff in ower opinion. i took these pics so you use your own judgment .
included is amp and factory boxes no remote gain or cable
Specs:
1 ohm stable 2 channel Digital Mono-Block
Low Level Input and Output
Frequency Response: 20Hz-350Hz
Input Level : 0.2V-6V
Variable Subsonic Filter: 10Hz-50Hz @ 24dB/Oct
Variable Low Pass Filter: 35Hz-250Hz @ 24dB/Oct
Variable Bass Boost: 0-(dB @45Hz
Fuse Rating @ 1000 Amps
Working Battery Voltage: 9v-18v
Dimensions: 650mm x 258mm x 132mm
Power Rating : * 14.4 volts = 11,400 watts rms @ 1 ohm * 18.0 volts = 15,200 watts rms @ 1 ohm
1400 shipped con u.s.
no trades...
http://i1148.photobucket.com/albums/o568/calp1258/100_0952_zps75c3c1c1.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0951_zps667fff7b.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0946_zpsa84b2bc9.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0947_zps62a33afb.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0948_zps29f3e954.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0949_zps08885b22.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0942_zps85907112.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0941_zps7fc5f7cf.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0940_zpsa5978da7.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0953_zps6f4b1ffe.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0939_zps0a178f56.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0943_zps7e98d7fa.jpg
http://i1148.photobucket.com/albums/o568/calp1258/100_0944_zpsad907edb.jpg
A.B. VFL 1000.1
Specs:
no trades...
