Am I missing something here on MB Quart stats?
OK, then why is it not 250x4 at 4Ohms if it is 500x2 at 4 Ohms?
No, you're getting majorly confused.
It's 4x125 4 ohm thats 500 watts at 4 ohm
It's 4x250 2 ohm thats 1000 watts at 2 ohm
It's 2x500 bridged at 4 ohm thats still 1000 watts except it will go to 2 speakers instead of 4.
I appreciate the manual link, but it does not say what the power will be in 3 channel operation. That is why I came to you guys for some help on it. This is kinda where all it all began -- "Will I still get 500 from the rear if I stereo the front channels and bridge the rear?" or is it going to be 300 (150 x the bridge)? The manual says to put it in mono mode if you bridge both. Is it "mono mode switch" that is spitting out more power through one channel or bridging? If bridging (which I suspect), then what does the mono mode switch do?
The above is from the MB website. I am thinking of getting this amp...but.....How can it be 4x125 RMS and 2 x 500 @ 4Ω? Wouldn't it be 2x500 @ 2Ω? And more like 2 x 250 @ 4Ω?
When you bridge an amp, you combine two channels into one. When you do that, if the each channel puts out full power at 2 ohms, then the bridged channel will also put out rated at the equivalent of 2 ohms per channel, or 4 ohms. Does that clear it up for you?
YES! I get it now. So it is performing at 2 ohms per each channel x 2 (equaling 4ohms total). That makes sense. OK......so I am super slow. Thx for taking the time!
Starting to come together now?
You have the 4 ohm stereo rating -- all channels operating at 4 ohms -- 125x4, simple enough.
Then you have the 2 ohm stereo rating -- all channels operating at 2 ohms -- 250x4 still pretty simple. The impedance drops by a factor of 2, so an amp with a strong power supply doubles its current output doubling power into the load. This amp apparently has a strong power supply.
Then when you bridge you're taking that 2 ohm stereo power, but combining it to drive ONE 4 ohm load per PAIR of channels. Essentially - each channel "sees" half the load, hence 500w x 2 bridged into 4 ohms.
And yes, a pair of 4 ohm speakers on 2 channels and a 4 ohm sub on the other 2 bridged channels = 125x2 + 500x1.
If you look around you'll see similar ratings from high quality amps. Lower quality amps typically don't double power at 1/2 the impedance because they have weak power supplies.
Bubblebass
Bubblebass
SoCal
okiedokie
    Jun 20, 2026
    Jun 20, 2026
