Am I missing anything? I am starting from scratch
JarvisB
JarvisB
I am ordering bunch of wires and accessories from Knukonceptz.com
I am going run a Kicker 2500.1 amplifier and a 15 inch subwoofer in the back of my 2004 Ford Explorer to give you an idea of what I am going to have in my vehicle.
here is what I have in my cart right now..
35 ft of 1/0 KLMX Power wire (for my amp to my battery, ground, and big 3--- 2500.1 got one 1/0 input and output correct?)
8ft of 10 gauge KASA speaker wire
In-Line Waterproof ANL Fuse Holder w/ Fuse(250 AMP)
2 Konfused Battery Terminals
1 250A ANL fuse (just in case)
eKs Kable 2 Channel Silver Plated RCA 2M
I am a bit unsure about the eKs Kable since it is 50 bucks for just 2M.. I am not sure if 2 meters is enough to run from my DD headunit to an amp in the back?
Otherwise, am I missing anything?
Let me know, I am going to order all of wirings and stuff tomorrow
Thanks in advance
mabye some ring terminals?
for what?
fuse and fuse holder for alt to battery...don't have to but should. rca's won't be long enough...i'd go 12 ft to be safe
Good point.. hmm so another inline fuse holder with 250A will do..
and yeah, but eks cable dont come in 3M or 4M so I ll have to get it in 5M and that is 80 bucks for this RCAs in 5M.. not sure if 80 bucks is worth it or not..
for what?
ground from batt to engine block...terminal at engine
batt ground to frame, terminal at frame
ground from amp to frame in back, terminal at frame
alt to battery, need terminal on back of alt.........at least 4 ring terminals needed.
as for the rca's theres cheaper out there
my bad, I figured that I wont even need a ring terminal but I completely forgot about the big 3 lol..
so I just threw in 5 ring terminals.. anything else?
JarvisB
JarvisB
JarvisB
MI/DC
JarvisB
