Hi All!
This is my first post so appologies for any novice mistakes!
I have aquired the Alpine MRD-M300 mono amplifier with the Alpine SWR-1241d 12" from a friend who I'm certain won't have given it any abuse and would have had it set up for him, then probably didn't touch it.
The Sub is in a box, I pressume wired in parallel (it's a typre r dual coil, 2 x 4ohm coils) to two connectors on the side of the box, set up to connect to the amp which, when powering the sub in 2 ohms, should match the 300watts RMS rating of the Sub...spot on match?
I'm using a head unit that specifies that the "Preout max output" is 2.2v.
In the amp manual, it has instructions for Input level, on my amp it has this Input level (3 stages I think...-12, -6, or 0db) then another option (no trace of in manual), for Input gain (3 stages 0, +6, +12db). In the manual it says it has Input level (-18, -12, -6, 0db).
On a different forum someone posted that it's not technically a gain as it's a digital amp?
Anyway, the apparent setting for a 2v Preout from HU to amp, is -12db.
I currently set the amp at 0db Input level and 0db on gain but I want to up the gain as I have to turn the HU up too much (too much to components) to get any real kick at all.
After all that...my question is:
Will I damage either Sub or amp if I up the "gain" so long as I ensure the amp overload light doesn't come on?
I'd appreciate any help!
Thanks!
Thanks!
