Am I doomed for a front stage?
Yeah You should try grounding your headunit if it's a pioneer. the same thing happened to me the other day. Tie speaker wire around your rca's tightly then connect it to a screw on the deck.
my RCAs already have that little wire that runs down the center, if i could use that.
did it help yours?
well i tried:
wrapping a ground wire around the RCAs
grounding the actual RCAs
Running new power and grounds to the deck
i think my fear is comin true... its the cd player //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif , its barely gonna turn 2 years old. Why do they always take the young ones.
if you regrounded it, and its still doing it...its the deck, man...
we tried everything else. The only time you got it to stop for a second or 2 was when you were messing with the deck/rca's..
it does sound awesome, minus the horrid hiss and whine.
i was having noise too. I changed the amps and boom, it was gone. I changed nothing else... not the head unit, not the wires, nothing.. just dropped a different amp with all the same wires and the problem went away instantly. Try any other amp and see if its the amp.
amp he is using was pulled from the plastic for the first time when we hooked it all up...still dosent say it isnt a possibility tho..
davidfre21
Is just a lil racist...
davidfre21
WesTex
InhumanAcura
