alternators or optima battery's? i need some help
  • Thread starter Unregistered
  • Start date
  • Replies 3
  • Views 887
U
Unregistered
Guest
ok heres the deal,im currentlly runing a cheap ass 900wt interfire amp to my punch hx2s it slams pretty well for only being like 200-250rms,n e ways i upgraded my stock battery,to a pretty good die hard i thinks its the best 1? well i ordered a 1000.1 mono rockford amp from off line and my lights dim like hell with the interfire amp and also i have a 1farad cap with it,i know by addin a cap it is only a bandaid to the issue but i was wondering if any1 out there knows where i can get a good alternator off line? no places around here carry high amp alternators only stock, and is the optima yellow top battery only good for and accessary battery and u shouldnt use it as a main battery?
OR should i buy a 2nd battary and wire it up somehow to the stock alternator and die hard i got?? i have no clue what i should do people around here dont know a whole lot so i wana come on here and get some advice.thankz
Adding the batteries is going to have the same effect as adding a cap. You need something to charge it first! As for hi cap alternator availability in your area- you may have to look arround a little. One place you may look into is an electric motor assembly shop- they can rewind your alternator for increased output as opposed to purchasing a new one. The best place to begin searching is your local yellow pages.
It would also be benneficial to ask arround a bit at some local Parts stores and dealerships- they tend to have a dood number of resources available to them that may assist you.
take it easy,
-zane
I have to agree with zane.
Also here is a test to see how much you will benefit from a H.O. alt. Check out your friends or families cars to find the largest alt you can find. Connect your car and theirs with a set of jumper cables. Don't start your car. Just turn the headlights on and crank the system. How bad are your headlights dimming now ?
I've got three years on my 320a iraggi. I haven't used any other brands so i can't say how it compares to others. Customer service was great...
Cat as in animal. I had it sitting out on in the box with the box open as I grabbing some connectors from the other room as it was on the one...
14
Johnson controls makes Optima batteries now. They also make most of the auto parts store and chain store brands. You will be just as well off...
953
Guest
ramos
    May 16, 2024
    May 16, 2024
