Alternator ?
LosIsATool
I Installed my HO today in the 110 degree heat only to find out I couldnt use the pulley that came with it. It has 7 ribs and my set up has 6, so I had to put my stock pulley on it until I hear something back from EA Monday.
The one that came on it could **** near fit inside my stocky, there for its not funtioning no where near optimal. I would think it would not make that huge a difference but I guess running a 2500 watt .5ohm amp does affect it a lot. It does OK at speed but idle will drop to the 11s quick and take some reving to get it back up to the low 12s.
Will the right pulley fix my drops? Or does the Alt ****?
---------- Post added at 08:49 PM ---------- Previous post was at 08:48 PM ----------
Im running 2 type rs at this moment so I dont need all the amp yet. It does OK at around 1600watts
use the pulley it came with, despite the minor differences it should work fine as long as the belt tensioner is in working order. It should not slip, if it does contact the company for the correct one with the # grooves you need.
LosIsATool
LosIsATool
Pensacola, Florida
Kangaroux
vegang
vegang
