alternator
I dont think youll have to worry about that lanzar amp pulling more than what your alt can put out cuz they arent very good amps(from what ive heard). IMO I think youll be allraight
most of them put out what they are rated at on the alt...mine is a 90amp alt.......so ur running aprox 800 total watts......800w/14.4v = 55.5ampers.....that amp will draw aprox 55 ampers max if it was 100% effecient....i'm goin to say its anywhere from 60-80% effecient....so your looking at 33-44ampers of current max
Originally posted by Goddyd4me most of them put out what they are rated at on the alt...mine is a 90amp alt.......so ur running aprox 800 total watts......800w/14.4v = 55.5ampers.....that amp will draw aprox 55 ampers max if it was 100% effecient....i'm goin to say its anywhere from 60-80% effecient....so your looking at 33-44ampers of current max
Um.. as the efficiency drops, doesn't the amplifier draw MORE current? to make up for the lack of efficiency? So if you had ~55 amps at 100 %, you whould have ~110 amps at 50%.. right?
And, no.. a cap wouldn't be what you want.. you would want to get your alternator re-wound or get a bigger alternator if you need one..
The best suggestion is to get the amps set where you need them and see if you have any electrical issues (like lights dimming, etc).. if everything looks ok you should be ok.. there is a good chance that you won't be running the amps at full power anyway.. if you do, you will probably need a new alt (or get your re-wound) as 800 Watts at 50% is ~110 amps...
Hope that helps..
holy crap this is all new info to me and im scared....
im gonna have 2 JL 300/2's and possibly a JL 500/1
right now my BMW is running a 140 ampers alternator...
do I need to buy a new biscuit factory ????
Depends on a lot of things, actaully..
Looking at 1200 watts (300x2, presuming 600, you said 2 of those?) you draw ~170 amps at 'full' power with an amp that is ~50% efficient. If it's up to 60% you draw ~140 amps at 13.8 volts.. add the other amplifier and you go up to ~240 amps at 50%.. Keep in mind, the 'max' for the amp is kind of pointless since you can't sustain that for long and will sound like crap up there.. I do my calcs on RMS since that's the 'real' power I'd be able to use.. if your 300x2 is 150 each channel and 75 RMS, you get ~45 amp draw (150 watts RMS x 2).. if it's 300 RMS per channel with 4 channels total, it's closer to ~170 amps..
This is based off a calcualtor I found ( http://www.eatel.net/~amptech/elecdisc/systemdesignassistant.swf ) but I don't how close to perfect it is.. seems pretty close to me.
The best alt I saw for my truck was 200 amp, and I need ~265 for all 1800 RMS of my bass. .isn't gonna happen for a LONG time... I'm guessing I'll be running only about 300 RMS to match my stock system, if that much.. maybe closer to 200 RMS..
not sure how the extra deep cycle battery helps for long periods.. or if you can run multiple aternators or not (I'd immagine you could but you have a lot of custom fab work to do)..
It all just depens, more efficient amps draw less current for the same power...
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
I don't have one...but I check my voltage with a dmm once a week or so
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
chase297
chase297
West Hartford, CT
Savant
