Alternator wiring help
UGHH
I meant amplifier wiring help. My phone changed it. smh I'm planning on buying 2 sets of Soundqubed mid bass speakers (front doors and rear doors) and a set of their super tweeters (dash). Will getting crossovers for the front speakers turn those 4 channels into 2 so I don't need another amp. I'm planning a full Soundqubed setup and they don't have a 6 channel amp. I don't wanna have to buy 3 amps total, wanna stick to 2 if possible.
Yes they will but you could also just use filters on the tweets and run them in parallel with the mids on the front channel. Or you could run all four mids on two channels of the amp and run the tweets on the other two. That would allow you to run an active setup and it would **** a bit more POWA out of the amp for the midbass drivers. :)
EDIT: You can't say svck on this forum?
Is this site owned by Disney or one of those batshite crazy creationists?
Cool thanks. Also the amp is rated at 120x4 at 4ohms. I'm not worried about the mids, theyre rated at 100rms but the tweets are only rated at 50rms and I know if you push too much power to tweets they get very harsh. Any way to limit the power to them? Would using your first option do that?
The AQ supertweeters come with caps, so you don't need an xover for them. For the mids you can use amp/HU HPF and FMOD's for LPF to create a bandpass...
I run those tweeters in the dash of the wifey's mini van, you will NOT need much power at all with them reflecting off the windshield.
UGHH
UGHH
Sacramento, CA
Side Show
