packardhell1 10+ year member
Getting back into it...
Hello all,
I just finished reading the sticky on "Engine whine and ground loop fixes", but it has not solved my problem. I've always had a little bit of whine, but it was almost unnoticable, so I didn't worry too much about it. Three days ago, it's gotten very, very loud. When I turn the Kenwood HU on, even if no music is playing, there is a loud whine. When I shift gears, I can hear it in the speakers, and when I hit bumps it crackles.
I drive an '03 Accent. I have 4 ga power and ground wire. It's grounded to a solid metal piece in the trunk. The RCAs and remote wire are run on the opposite side of the car as the ground, and the RCAs are shielded. I have an MTX Blue Thunder Pro 504 amp and a Clarion EQ. Both the amp and the EQ are in the trunk. I have no subs, just regular speakers. The amp is running at 4 ohms and the gains are low.
I've checked my wiring (power, ground, and RCA) for any signs of being cut/burnt/split/damaged and I couldn't find anything wrong. I haven't recently changed anything in my stereo.
I'm thinking the deck could be a culprit - it's just a cheapie Kenwood deck (the stupid CD loading mechanism doesn't even work anymore). Does anyone have any other ideas as to what could have changed? Do RCA cables magically become unshielded? Thank you for any help you can provide!
