alternator upgrade
You should also upgrade your charging system with what they call "the big 3" these days......and don't forget a good body to chassis ground also ....
very solid suggestion, i picked up some orange and black OFC 4 gauge with ring terminals last week, so im just gonna do it all at the same time. Should help with the dimming lights issue //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Most people use 1/0 for big 3. Can you double up the 4?
yea, depending on amperage draw, a 160a alt along with full charging system and ground wiring upgrade should take care of dimming lights ....A good AGM battery is also a plus ...
awesome, thanks man! at this point im only running the SQ2200 at 2 ohms, so the math at 12.4 volts is around 96 amperage of draw at full chat, also i didnt see these 2 posts before my battery question, my apologies
i could double up on it, i think i have enough
just be aware, that if you're out driving around in the cold(with the heat cranked, defrost runnin, and heated seats kicking),at night( with your lights goin strong), when it's raining(you get the point by now), and decide to crank your system, your "stock" charging system still prob won't keep up .....
Just be aware of that fact ...
i smell what the rock is cookin LoL Ill do the big three, hopefully with 2 runs of the 4 gauge ofc (if i have enough) get that alternator installed and some solid brass battery terminals, still havent done that yet either
youdoofus
Skibidi
youdoofus
planet earth
youdoofus
vegang
vegang
