alternator upgrade
A strong electrical system is the basis for a good sounding, reliable, long lasting car audio system. And should always be the starting point of a good system ....
any recommendations for good top post battery terminals? I know of some of the long known brands, but good priced good quality recommendations will welcomed
these look to be ok, all brass (so it says LoL) http://www.sonicelectronix.com/item_72370_NVX-XBTPN08.html
---------- Post added at 02:16 PM ---------- Previous post was at 02:15 PM ----------
is this going in a uni body car? Or a full frame vehicle??
unibody. 02 accord. I assume that that that ill strictly NEED to do is swap the alternator and itll work just as well(likely better) than the current one, but STRONGLY recommended to do all the aforementioned upgrades to optimize performance, correct? Sorry if thats a dumb question, i just dont want to blow anything up after i put it in and start it
Having multiple runs probably isn't going to help. The path of least resistance theory not the pushing power down multiple lanes theory right? Having O gauge help because over the normal 8 gauge the path of least resistance is the O but if you have multiple runs of the same it's only going to pick one 4 or the other right? Go to a lowe's or something and get 0 gauge welding cable it's pretty cheap.
Do the big three 1st no sense doing an H/O alt and not having the big three. Brand new battery is not necessary depending on what you have now more info there please. As for connections easier to just use ring terminals bud.
Ummmmm... no...
Multiple runs does help. Two runs of 4 gauge ~ one run of 0 gauge.
Also, OP, leave stock wires when doing the big 3. Only add wire.
Multiple runs do help but two runs of 4 gauge will have less strands than 0 gauge. Probably not enough to make a real difference though.
Yea, they're about equal. Definitely makes a difference to double wire though.
Also. boomsday has a battery that goes hard in the taint son. I would grab one before he sells out.
Taint?? I think you mean paint, haha. I could be wrong
youdoofus
Skibidi
youdoofus
planet earth
youdoofus
BP1Fanatic
BP1Fanatic
