ejschultz
Factoring in the stock electrical components isn't as important as you think it would be. Sure the headlights pull about 15 amps and the A/C can pull upwards of 30 amps. What do you think a stock 105 amp alternator does at idle? I'd assume it's close to 30 or 40 amps at idle. If you're driving at night and you have the A/C on, you'd be f*cked with a 105 amp alternator as soon as you come to a stoplight. I think a 140 amp alternator would definitely be an upgrade for you. It wouldn't be a huge upgrade, but it would suffice for the kind of power you're pulling right now and if you upgrade later on to 1500 watts, it's definitely going to be better than a stock alternator but you'll probably still have some voltage drops. I'm currently doing about 1300 watts RMS with my Caprice between my mono amp and my 4 channel. My mono amp is 80% efficient; I'm not sure how efficient my 4 channel is. I'm running a 140 amp alternator that benched at 98 amps at idle and 163 peak. At full tilt, I get a slight voltage drop, but nothing like I had before. I used to dip down into the mid 11s with my stock alternator (105 amp) and a big 3 with 1/0. Now, the lowest I've seen, at full tilt, was 12.8 volts at idle. My headlights don't dim anymore. I can definitely tell that the alternator made a difference.
