On the OP's car or yours?It was 14.4 with the radio on.
how do you check the voltage on the back of the alt???You could have one of the following
Weak Battery
Bad factory Cables
Weak Alternator
The factory cables can corrode underneath the jacket where it is not visable. That is why I suggested to check voltage at the back of the Alt to see if there is a drop from what you have at the battery and what the Alt is putting out. The higher the amperage against higher resistance would cause the drop to be more severe under load then at idle.
What does the battery sit at with the car off? Measure after the car has ran around town- wait about 30 minutes after turning car off to measure so the voltage can settle.
I'm:
14.2-3 idle
14.4 @ 2000RPM
14.1 AC on full blast
12.5 car off
~10v @ full tilt
Hope that helps.
awesome but one thing i dotn have the stereo in right now so can i turn on some of the other gadgets to create a load of some kind??Back of the ALT is a large stud, that is the postive output, put your red lead there and ground the black lead. Compare voltage at the battery and at the Alt under load (stereo on)
Every car is different as the regulator for that car is different, most 90's GM cars range from 13.8-14.2
AC, Headlights, roll your windows up and down?awesome but one thing i dotn have the stereo in right now so can i turn on some of the other gadgets to create a load of some kind??
So you have stock stereo?My car: 99 Grand Am GT: No audio: 13.8 Radio On & AC 12.5
Non of the cars have any sorta amplifier in them including mine.
no i dont have a stock stereo i have a new HU and the whole other crap subs amps and what have you.
?????? Do you read what you post....LOL If all you have is an new HUin the car I'd say that is stock since you have nothing else drawing power in the car that is not there from the factory.
If voltage dips/spikes to 12.5V with just factory options (AC, Rear Defrost, Lights) and comes right back up into the 13.8 range that is normal. If it is a spike, but it stays there, its a low reading. By spike I mean the second that accessory is turned on, you'll hear the idle drop, voltage will drop and then recover in a matter of seconds. If it stays low, you have a problem
