alternatives to sound deadening
nathanh
i went to the audio shop and they wanted 100 dollars for a trunk kit. for some reason i think there might be a little bit of a mark up just cause there is a name on the foil. there any off brands or like bulk building materials of the same property?
raamat is popular on here
so is some oethers try searchin!
i am sure there is a building material. there has to be. i just havn't found it yet. you could stuff your doors with r80 insulation lol
Well, you could ask is anything we do necessary, in getting better sound //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It wouldn't hurt, but if you're looking for places to start, any doors/things that latch would be where I'd go first. Then the floors, firewall, roof, etc...
This is a offshot, but you could try replacing any broken door panel connections (if need so), and tightening down the screws in places where there are buzzying noises. Worked for me.
I have seen people online use this stuff:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100012574&N=10000003+503272+10072001
I tried it in my last car with minimal effect at best. It managed to dampen vibration in the cars trunk top/back/sides; but it shifted the vibration down to the underside of the car, coming from the wheel well. But it's really cheap.
I don't really suggest using it, but it's an option.
Beware of stuff not specifically made for car applications. Most of those products (ie Peel and Seal) have a lot lower heat tolerances than say Dynamat. You may end up cleaning tar adhesive from the bottom of your trunk.
nathanh
nathanh
stanwood, wa
audioholic
