Alternatives to cup terminals?
Buy these from home depot. SKU # 608576
1/4-20 x 20mm Zinc-Plated Steel Type-D Insert Nuts (4-Pack)-54454 at The Home Depot
Drill a hole a little smaller than the insert, apply some wood glue and twist them in with a hex head. There will be absolutely no leaks at all when you use these screws from Home Depot. SKU # 254827
1/4-20 x 2 in. Coarse Brass Flat-Head Phillips Machine Screws (2-Pack)-30171 at The Home Depot
I'm very happy with the way mine turned out
LOL thank you, he kinda sounds like a jackass. Idk how bit of holes ure drillin buddy but i said big enough for the wire. Theres not alot of air that could get threw lol
THANK YOU for assuming things.
But I'll have you know that I'm still supporting my idea. Say you do a test with caulk and then no caulk with eteris paribus. Report back and tell me what the difference was in dBs between the two tests.
ill pass, u do it and get back to us
I'll probably go with some simple wing nut/nut/washer setup. Don't like the idea of sealing a hole with caulk. Wth do I do when I have to change speaker wire for whatever reason?
you pull it out.... it's not THAT strong. Any designer/builder I've talked to have said if it's a ported design, it's not a problem just drilling and running wire through. if it's sealed, that's a different story.
yank that shit out man, lol
Or just use quality wire and don't cut your runs short if you relocate the amp later. Will be no reason to change the wire then
I've done the whole "just run the wire through and caulk the hole" and not only did I have problems with my caulk getting blown out of the hole but it was a PITA if I had to remove the enclosure (having 3' of dangling 10 gauge wire was annoying and inconvenient to say the least)
The Dayton terminals are the best for this type of application. Dayton Audio BPA-38G HD Binding Post Pair Gold 091-1245
If you're worried about them shorting out, recess them by drilling counter-sink holes or 2nd using piece of MDF as a baffle board.
Otherwise I just run the wires straight out of the box using sealant or stack nuts and washers like this: Bolt - Washer - Terminal - Washer - Nut - Washer - Terminal - Washer - Nut. Washers on both sides of the board and on the terminal. This way you can loosen the nut without the bolt turning inside the box.
If you're worried about them shorting out, recess them by drilling counter-sink holes or using a 2nd piece of MDF as a baffle board.
Confessed
Confessed
Gainesville, Tx
TexMexThugga
NorthFramingham
    Jun 30, 2026
