Alright, Kicker Comp VR - VS - Infinity
wow..I feel dumb //content.invisioncic.com/y282845/emoticons/blush.gif.99bc659ee2012b7d826165e26fb5eebe.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif//content.invisioncic.com/y282845/emoticons/hide.gif.2d479cfd917eedfe201353b91522ceab.gif
daaaaaayyyyaaaaaamnnnnnnn.. 400 dollars for a perfect over there? is that US dollars? could i convert 200 US dollars to 400 EU dollars or something or is that just how europe is? everything is more pricey? thats crazy cash for a perfect if youre talking about US currency. they sell them at crutchfield for 179 now.. they use to be like 250-300 a lil while bacc. but yea out of those you listed id definitely go with the perfect.
Yes, pherhaps it seems pricey for you. Im not going to brag, but dont forget that people in Norway have bigger wages than in the states, in overall. So the price might be a little higher, but we earn more too. Besides, the dollar is really weak compared to the norwegian krone right now, so that has a big influence too.
ANYWAY,
I'd keep the two 12's, and add power later.
PS Thanks Kurt!
Im unsure.. this is what I got now:
Megaforce 2120 .
MAGNAT: Nominal Power handling 350 Watt
Max. Power handling 700 Watt
Impedance 4 Ohm
Ulower cut-off frequency 18 Hz
upper cut-off frequency 500 Hz
soundpressure level 94 dB
Specials 40 oz. highpower magnet System 10”/12” highpower subwoofer Silver coated screw terminal 2 to 4 aerodynamic bassports Screwed plexi window 2”high performance voice coil Cabinet with high damping carpet.
VS
KICKER CVR:
Outer Frame Diameter, in (cm) 12 1/2 (31.8)
Nominal Impedance [Zn], ohm [per coil] 2 or 4
Power Handling Watts, Peak (RMS) 800 (400)
Sensitivity [sPLo], dB @ 1W, 1m 86.7
Effective Frequency Range, Hz 25-500
Mounting Depth, in (cm) 6 3/16 (15.7)
Hole Cut-Out Diameter, in (cm) 11 1/8 (28.3)
Equivalent Volume [Vas], ft3 (L) 3.37 (95.37)
Net Displacement, in3 (cc) 122.1 (2001)
Moving Mass [Mms], oz (g) 5.52 (156.4)
Magnet Weight, oz (kg) 47.05 (1.334)
And remember, this is 350watt shared by two 12". (Magnat)
And my amp only puts out 210watt in 4 ohm.
With my amp I could put out 420watt in 2 ohm on ONE 12". (CVR)
One CVR do cost almost as much as the Magnat sub. (two 12" and the fancy box).
What do you think?
1,00 Euro = 1,26 U.S. Dollar
100,00 Norwegian Krone = 15,48 U.S. Dollar
I see that you have the same amp as i do. (Kicker KX 700.5)
And two CVR's.
How does it play?
420w / 2 = 210 watt each. Does it kick? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
deComposion
deComposion
Europe -> Norway =)
Polecat
ThxOne
    May 13, 2026
