Sold Alpine Type-R 12", Sealed/Vented Box, Infinity 400W amp
darksparkz
Alpine Type-R Dual Voice Coil 4-Ohm SWR-1242D 12" Subwoofer $100
Q-Logic Single 12" Sealed/Vented Subwoofer Enclosure $60
Infinity Reference 1600a Mono Subwoofer Amplifer 400W RMS @4ohm $140
Total: $275 Local Pickup in Chicago, considering possible shipping, but at buyer's expense.
They are in pretty much new condition. I've only had them in for about 3 months. These were put in my '97 Camry, I ended up getting a '07 Camry a few months back and now my brother has the car and doesn't like the bass too much. I've only pushed them to 400W max, so still a lot of potential in them, but they sound great in my opinion. I purposely didn't want something hard hitting, but you can always upgrade amp if you feel that this is lacking.
Specifications:
Alpine 12" Type-R
* Handles up to 1500W peak power (500W RMS)
* KEVLAR-reinforced pulp cone, oversized parabolic dustcap; HAMR surround and concealed mount gasket (KEVLAR is a registered trademark of DuPont)
* High-strength brass voice-coil bobbin; 50mm voice-coil diameter
* Dual progressive oversized Nomex spiders with integrated tinsel leads for added stability
* Dual stacked magnets
* Custom cast aluminum frame with integrated heat transfer plate; radial vented VC heat sink and airflow management system
* 11" top-mount diameter; 7-3/4" top-mount depth
* Magnetically optimized motor structure
* Frequency response: 25Hz - 500kHz
* Sensitivity: 85dB
* Impedance: 4 ohms
* 894W peak output @ 2 ohms
* 400W RMS output @ 4 ohms
* 600W RMS output @ 2 ohms
* 12dB variable 32-320Hz low-pass electronic crossover
* Full-range preamp outputs permit multiple amplifier hookups without adapters or splitters
* Bass boost optimizes low-frequency performance of system based on vehicle type and woofer location
* Class D switching power supply draws less current than amps in other classes
* Single 12" subwoofer enclosure; space-saving wedge-shaped design
* Interchangeable baffles to accommodate different types of subwoofers
* 1.25 cu. ft. chamber with sealed or slot-vented capabilities
* Heavy-duty 5/8" MDF construction
* Nickel-plated 5-way binding posts
* Blue and black carpet exterior
* Includes woofer mounting screws, poly fill and speaker wire
darksparkz
darksparkz
Chicago
darksparkz
