Alpine Set-Up
3G_Clips_RS
Ok, whats the best box, and tune settings for the following gear?
I plan on wiring it like the second way listed at the following link:
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp=Dual+Voice+Coil+-+2+ohms+x+2&image.x=3&image.y=9
Also, how many Ohms will this set up run? All Alpine amps are 2 Ohms stable. The following driver (The alpine SWR-1222 Type-R) is 2 Ohm + 2 Ohm. There will be 2 of them wired as above. Also, how many watts will each driver get max and RMS?
Drivers: 2 Alpine SWR-1222 (Type-R's)
http://iweb.alpine-usa.com/pls/admn/item_info?p_item_name=SWR-1222D&p_category=70&p_subcategory=150&p_main=10
Amp: 1 Alpine MRD-M1005
http://iweb.alpine-usa.com/pls/admn/item_info?p_item_name=MRD-M1005&p_category=40&p_subcategory=140&p_main=10
Thanks in advance.
i jsut got the alpine mrd-m501, picked it up for 145cdn (125 usd)
got it powering a type r 12 in 2.8 net @ 32 hz, pretty loud, gotta go adjust everything properly later on though,
3G_Clips_RS
3G_Clips_RS
Spanish Fort, AL
hdave
BP1Fanatic
BP1Fanatic
