alpine problem?
ledzeppac
Hey guys,
I setup my alpine f 450 4 channel running to kicker ks comps the other day and right away I had issues. They were not getting loud and the amp would go into thermal protection mode after 20 minutess. I ruined my crossovers becuase they were glowing white as day, they work but the sound coming out sounds like I'm in a tunnel..
I changed the grounds, checked for volt droppage at the terminal and ohm'd the speakers which ohms to 3.7 a piece.
I got the amp from Ikesound.com... is there anything else I can check before I try and send it back to them?
thank you
glowing white as day = too much power to them..turn the gain down
oh yah... I was only giving them 14.4 volts... which according to the chart I have would be perfect for 50 watt speakers...
Also, I did turn gain down to only give them 6.5 volts and they still glowed like fire. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
is that all the way down? do you have an aftermarket headunit?
pretty close about 1/4 the way up....
Its a panasonic cq-c7300 I got from a friend. I think it is a european model or a middle east model. None the less still a 2 year old panasonic.
I'm already pretty pissed I ruined a good set of speakers.
Any ideas?
ledzeppac
ledzeppac
orange county, ca
TreyE
