Alpine MRP-F450....noise problem
SYSTEM: I am running Alpine F450 four channel amp to power Polk db6500 component system in front and Infinity Kappa 693.7i in rear through stock radio of 2004 Accord EX.
PROBLEM: If I turn gain any higher than minimum, amp create a very noticeable noise in the back ground. If I keep the gain at minimum, there is no issue. I am wondering, if it's because of stock radio? or bad amp? or is it normal?
PS: I am using speaker level input to connect this amp directly to stock radio without hi-low converters. I tried to use hi-low converter earlier and it had same noise issue. Any suggestion would be highly appreciated.
f2ajack
f2ajack
san francisco, ca
Raffi
