alpine imprint vs seperate eq
Don't waste your time on Imprints Auto eq. How much processing are you going to use out of it? Par EQ, Time Alignment, 3 way crossover. If you are just running passive, Louisiana_CRX's recomendation of the eq is a cheaper better solution.
I think most of Alpine's newer head units are set up with no real built in tuning specifically so you have to buy a separate add-on module, and they hope you'll be convinced IMPRINT is the end all, be all and give them the extra money rather than spending it elsewhere.
I hear IMPRINT cuts bass frequencies rather aggressively, getting you a very flat frequency response but a real-life sound that won't initially be right if you don't work around this. Also you have to experiment alot with mic positions and play with it a bit to make the computer do a tune you like. Seems like it ends up being more work than taking a bit of time to play with a separate EQ.
And once you set IMPRINT up I don't think you can go in and make tweaks and adjustments to the computer tune, you live with it as is or you start over. Probably a good alternative to using some of the instruments necessary to tune textbook style using a separate processor, or to doing the measurements for time alignment. Just sucks that you can't use it to get a baseline and then tweak it from there. I had no interest in it. I went to a Pioneer HU with built-in time alignment, built in sub, front, and rear crossovers, and a 16 band graphic rather than keeping my Alpine and paying for IMPRINT. I can adjust it on the fly as I want or pick any of the pre-programmed EQ curves and then adjust from there.
My pio also has a less elaborate auto-tuning system built in that sets the EQ curve and time alignment, all I have to do is plug the mic in, set it on the faceplate, get out and close the doors. May or may not play with it at some point.
BigAl
BigAl
birmingham,al
cleansoundzz
