alpine h/u equalizer help
  • 4
pj_chevy03
please ban me
928
Alabama
i just installed an alpine cda-9830 and it is freakin awesome. lots of features and tuning options.
this is the first time for me to tune an equalizer and have a few questions. it has 4 bands with each band containing 3-5 frequencies.
band 1..........40-60-90 hz
band 2...........100-150-200 hz
band 3..........500-700-1000-2000-5000 hz
band 4.........10,000- 12,5000-15,000 hz
i want to boost the frquency of 40 hz to about 7+ but i only want to boost the frequency of 90 hz to about 3+, but when i save the setting of one frquency it changes the other frequencys within that band to the same setting. for instance, if i set 40 hz to 7+, then 60hz and 90 hz will also be set 7+. is that how it is supposed to work? I thought i would be able to tune each individual frequency within the band and not just the band as a whole.
also could someone please explain the (Q) bandwidth thing. it has setting of 1.0, 1.5, and 2.0 and i have no idea what this means.
thanks
doesn't that h/u have the feature where you can go to the alpine site --set all your preferences--download it to cd--pop the cd into your head unit and it will set it up for you? i know the 31 and 35 have that option.
from what i understand... u can only adjust one of the frequencies in the band...
in band 1... you can choose either 40... 60... or 90... and adjust it from there... the "q" factor is the width of the frequency... 1... if u want a narrow peak... 1.5 if u want a medium peak... 2 if u want a wide peak
read through the book and read everything on setting the equalizer... it will explain it all
from what i understand... u can only adjust one of the frequencies in the band...band 1..........40-60-90 hz
so basically since i wanna boost around the 35-50 hz range without boosting around the 90 hz range i should raise the 40hz frquency and give it a narrow peak?
boost at 40, and set the Q to 3, or whatever is highest
low Q = wide
high Q = narrow
oh ok thanks man. i thought a low q would be a narrow peak but i guess i had it backwards...thanks
EDIT: i just looked back up at slody4futbol and he says that a low q is narrow...so which is it????? hhahaha i'm confused
345
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
607
The one set of components are spoken for. On trade with @spokey9
16
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
pj_chevy03
please ban me
pj_chevy03
Alabama
Slody4Futbol
    May 24, 2024
    May 23, 2024
