redcalimp5
Loud 'N Clear
I've got a 7998 that I'm using to run a newly installed set of Boston PRO60's with, and I've currently got them bi-amped using the passive crossovers. The switch on the side of the 7998 is set for 2 way active configuration.
I was hoping by bi-amping these comps, I'd have more optional flexibility with adjusting crossover points on the HU...is that not correct? Is this only acheivable in 3 way active mode on the HU? This is the first time I've bi-amped a set of comps through passive crossovers, so I'm learning.
When I go to the crossover settings menu on the 7998, everything is set to 'Off', and I can't adjust any setting in there. I can only adjust Time Alignment and the User/Parametric EQ.
Anyone have any experience with this deck and bi-amping?
