Alphasonik PMA1200DA 1-Channel Amplifier
cheefrawker
I was originally gonna go with this Soundstream Amp...
Soundstream Tarantula - Soundstream Tarantula 1 Ch 2000 Watt
* NUMBER OF CHANNELS 1
* OUTPUT POWER (WATTS):
* RMS @ 4 Ohms 2000
* RMS @ 2 Ohms 2000
* T.H.D.:
* FREQUENCY RESPONSE (Hz): 20 - 500
* SIGNAL TO NOISE RATIO: >86dB
* CHANNEL SEPERATION: >60dB
* DAMPING FACTOR: >500
* INPUT SENSITIVITY: 300mV - 5.0V
* CROSOVER SLOPES: High-pass/Band-Pass 24dB
* CROSSOVER FREQUENCIES (HZ): Low-Pass 35 - 500
* HAWKINS BASS CONTROL (SUBSONIC POSITION): Variable High Pass (no boost) 13 - 30Hz
* HAWKINS BASS CONTROL: (On position)
* Variable Bass Boost 30 - 70Hz
* Variable Bass Boost 0 - 9dB
* DIMENSIONS (INCHES) : 19 x 14 x 5.5
Cheapest I could find it (so far) is $999.99. I only need the 2000 watts @ 2 Ohms power for either the CMPX212 or the CMPX215
Then I heard Alphasonik was pretty good and I found this one...
# 1300 watts x 1 @ 4ohm
# 2000 watts x 1 @ 2ohm
# 2400 watts x 1 @ 1ohm
# Linkable with Second Identical Model (Hardware Included)
# Hour Meter
# Remote Mount PMA100V Digital Volt Meter
# Remote Mount PMA10B Bass Boost Control
# Heavy Duty One-Piece Extruded Aluminum Heat Sink
# Beveled Clear Acrylic Protective Cover
# Tiffany-Style RCA Jacks
(theres more features but too much to copy). An it's only $374.35. That a big *** difference and I wanted to know if there was a reason. I know some guys like Boss Audio and Power Acoustik post rated numbers that they never really reach I was wondering if this was the case with Alphasonik
I've read benchtests done on that amp and the results 2600-2800rms with a good electrical system. search and you'll see for yourself.
another thing alphasonik was bought out by Audiobahn....that does not mean that Alphasonik's perform the same as Audiobahn's....Im sure they didnt just fire all of Alphasonik's original developers/tech's.
Thats just like saying Directed is the same as PPI and Orion....Do those 3 companies amps perform the same?
hmmm....ok...I guess that works for me. I mean of course i;m REALLY trying to get out of paying an extra $600 but I also wanted to make sure that it was still as good or near as good as the Soundstream. I'm gonna run it to a CMPX215 it seems and I want SQ. I was just hoping it wasn't gonna create mass distortion and sound like crap. So so far it's 1 to 1....neone else?
I have heard the same from several people. They are worth the money. I was going to purchase two but the seller was a lazy *** and never got back to me after repeated attempts to contact him.
cheefrawker
cheefrawker
El Paso, TX
skmfkr
