Im considering going to 2 4in ports, it would be a pain to redo my box to a large slot port but maybe my dudes up to it. I have 1.2K on tap but my OA dosnt want more then 800 or so in that box. Both SPL audio and the guys at OA said the box was rather large. But my builder wanted a very low resident Fq for the box since i want my lows as loud as possible lol so it just dosnt take as much powai gain 4-6 depending on the system im running, port area is part of it, but it also has a lot to do with the vehicle,
a tahoe that i meter looses a good 4db by when something is open. it just how things work,
and you are a good bit short on port area, i would say at the least add another 3", but it would probably be better to go with a pair of 4" or a single 6"... how much power?
No its opposite for me. My bass gets a bit better/deeper with windows down, but you open a door and it gains 3-5db(maybe more). Deff a good audible change, very noticeable to anyone in the car.Haha get used to it. I also have a regular cab truck, and the bass is so much louder with both windows open. It is unfortunate, I know.
go with a slot port, you want to try to keep the cabin pressure down...Im considering going to 2 4in ports, it would be a pain to redo my box to a large slot port but maybe my dudes up to it. I have 1.2K on tap but my OA dosnt want more then 800 or so in that box. Both SPL audio and the guys at OA said the box was rather large. But my builder wanted a very low resident Fq for the box since i want my lows as loud as possible lol so it just dosnt take as much powa
So after reading everything looks like it time to redo the box for more port and possibly take some space out. Thinking ill make the box 1.9-2cu^ft @ 30Hz with 2 4in aeros or a slot port. May just end up doing a whole new box, but if i decide to go that route ill probably switch to 2 10s
Lots of responses and good info, thanks guys. Ill be sure to post up a log of whatever i end up doing
EDIT: also considering going to a bigger 12, 1-1.5Krms area
WHAT iPhone do you have???your probably right man, like i said my iphone calculator ***** because i cant use parenthesis.
What? How would a slot port help keep the pressure down vs an aero port? And isn't his goal about increasing the SPL with the doors shut.. not decreasing it?go with a slot port, you want to try to keep the cabin pressure down...
Don't just switch out your ports for something you think will work. Who designed your box? Depending on the flare that the port has, you've got a very small window of what will work for what you want it tuned to. 14sqin for 2.2cft is on the low side. If you increase the area, you have to increase the length to maintain the tuning. If you increase the length but don't increase the box size, you decrease the net volume consequently requiring less port area. Then you have to iterate a few times to find the right area/length/volume combo. It's less headache to make a new box.
You say you want 2 4" aeros at 30hz from 2 3" aeros at 33hz. You're going to have a significantly bigger box even after the 0.3cft reduction. And if you're lowering the tuning, the probability is very high that you wont get the loudness you're looking for with the door shut since you're likely tuning away from your cabin gain freq. If you tuned upward, you'd get that loudness but skimp the
what I have been told is that aeros are really good for keeping cabin pressure up... in this case, the op doesnt want more cabin pressure because that is more pressure against the front wave of the cone... if he has less cabin pressure (open door) the subwoofer doesnt have to "work" as hard as it does sealed.. but I could be wrong.
Well i can open the box up to accommodate for larger ports but switching to slot would be a pain and not likely worth it. Honestly the options that wouldnt be to difficult to do is go 1in bigger on the ports. If thats not really a good option i might as well do 2 10s(get 500-600wrms a pop), or do you think i could do just as well with a 1-1.5k 12? I could just get a bigger 12 then do a new box or vice versa
iPhone 4 lol. When I type in a=pi*r^2 it squares the whole thing. So if I had done it properly I would have had to square the radius then multiply by pi. It's not that complicated just annoying lolWHAT iPhone do you have???
