allout13's acura integra build log
You can do just a straight up circle baffle that will cover the hole, you can go up to 1" without cutting anything really.
Anymore than that and you gotta cut up alota stuff i would know..
Op if you run into any issure ive had my integra completely stripped multiple times, dash included.
You can do just a straight up circle baffle that will cover the hole, you can go up to 1" without cutting anything really. Anymore than that and you gotta cut up alota stuff i would know..
is that an integra door? how the hell u got the panel back on?
got a good bit done today
got the crossovers and mids mounted. the tweeter output on the crossover I put in the passenger door had crapped out so after I got the door put back together I had to pull everything back apart.
tweeters were a pain in the ***. the wire was so flimsy that when I crimped a butt splice on it cut right through the wire so I had to solder some better wire on
everything mounted and in place. Im thinking about grinding down the factory tweeter grills as per madmat's suggestion, but until then...
mounting the amps tomorrow
what kind of wood did u use to build that baffle i have the same car and getting the same speakers so i was wondering. it won't fit into the stock one
Sweet build bro. I guess you are going to have the louder teg in GA out of the two of us, and probably one of the loudest in GA if I had to guess.
Kevin
sure thing.
3/4" mdf
looking good Chad. Let me know if you need any help with it. cant wait to hear it when its done
thanks, jared. Im pretty much done, just waiting on a box and the subs:D
Kevin
I appreciate it.
Im hopin for teh dbzzz
Freaking Molex plugs!!!!!!!!!!!!
I spent 4.5 hours yesterday doing the driver side door speaker wire yesterday! I went to start on the passenger side and realized that I couldnt even find the opening in the cabin.......
Kevin
still waiting on my subs to come in. my fingers are crossed for today
ok cool if you need a box hit me up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If I wasnt having another box built for free, Id definitely hit you up. I may anyways for a second box. can you do kerfs?
Kevin
best thing to do would be to tape like a hanger on the end of the wire and it will push right through the opening so you can find it coming into the cabin.
I cant stand those things. I spent forever trying to get the plugs apart, and then when I finally did get it apart, I looked at it and said FUCK THAT
yeah i hear those molex plugs are a *****. i never went through them myself. stock speaker wire was fine for me
thats what I eventually had to do //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif oh well. Im only running about 35watts through each door anyways
Oh ****. I ran the 14 gauge because I am going to have 150-200 going to each door lol.
Where are you in GA? I am in Alpharetta.
Kevin
haha
yeah probably a little more helpful in your situation to run bigger wire
Cartersville
got one of my konaki's today. ups beat the hell out of the box, and the shipping material is pretty crappy. the only thing between the bottom of the motor and the ground is the box
just waiting on the other sub now before I can start putting stuff in //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
allout13
allout13
Georgia
allout13
