alero factory hu
yea, its my car actually...my factory is working, but the display was punched out...so for now, for cheapness in my brokebutted ways, so for 30 bucks i can get another GM radio, so just wanting to know if a 2002-2004 radio will accept the factory hardwire plugs from the 2000 car
Nope. Different harness, different radio. The chassis size is the same, but the 2002 is a data-bus radio; it switches on and off from the data bus, not a switched ignition wire. Even if you cut out the old harness and install the new type, it won't work in your car.
thanks, so on 2002+ cars, does have any affect on an AM head units?
also, can i use any GM radio from the same year in my car??
Yes, many newer GM vehicles can be a challenge for aftermarket installations; typically you have to find accessory power somewhere other than the radio harness, and you may lose some vehicle features such as door and warning chimes.
2002 isn't the magic year for all GM's, though. The Cavalier and Sunfire went to a data bus radio in the 2000 model year, while some other models (such as the Blazer and Grand Prix) switched much later or not at all.
As for the second question, you can use any GM double-din radio that uses a 32-pin harness. This would include many 95+ Buick and Oldsmobile radios, but no Saturn or Chevrolet radios (and I don't think any Pontiacs). Examples would be the late 90's Cutlass Supreme, Buick Skylark or Buick Century; any of those radios should work in your Alero, assuming the Theftlock system isn't activated.
95+...ok...well i have a 95 camaro, with a bose CD player...can i use that in my 2000 alero???
Definitely not. Won't work because it's Bose. Won't work because it's the wrong size. And it won't work because it's a different harness.
shugar!! oh well. anyways, thanks for the input. that cleared up a lot for me. thanks!
Mr. Opportunist
Mr. Opportunist
Chicago, IL
phinger23
