Alarm Question!!!
sangerdude
Ok, I have been lurking and reading as much as I can but can anyone comment on the AutoPage brand of alarms?
I am looking to have one installed tomorrow on my 07 F250 and I do not want the remote start feature because, as I understand it, you lose a key???? Is this standard on the remote start feature???
Or should I go with a Viper 1002 model?
Thanks in advance!
Bill
In order to start the vehicle by remote, you have to get around the factory anti-theft system that uses a specially coded chip in the key. One way to do this is to install a coded key into a module that sends the key signal to the vehicle during remote start. However, modules are available that will do the same thing without losing a key (though they may be more expensive). The brand of remote start doesn't matter; just the type of anti-theft bypass module you use.
What would a module as you describe cost?
I would like a remote start but dont want to lose a key, we only have the two:D
The shop I am looking into did not even mention a mod. to do what you describe...
I would def. do that though...
What about the 4 window up or down module that can be added? Are these reliable or do they tend to eventually not work?
I appreciate your help with this! I am very unedumakated when it comes to this stuff, but I love to learn!
Bill
The shop shouldhopefully have a remote start bypass module for your truck that is keyless. I think the part # is 1100F. You can enter your vehicle here and search for a module. Only shows one for 07 Light Dutys, but probably the same.
http://www.directedstore.com/InterFace.asp?make=Ford
The window up/down module would be more of a novelty thing, unless you think you'd actually use it once you got over how cool it is.
sangerdude
sangerdude
Central Cali
hardhitta47
Mike Mccabe
