Lurius
If you had to choose one or the other for a distribution block(4 gauge to two 8 gauges) what would you choose, and why?
-Lurius
-Lurius
the main difference is the amperage ranges. AGU goes from 20(iirc) to 80, where as ANL goes from 60 to 300 (again iirc) and it costs more. Given that 8 gauge is not capable of conducting any more than 35amps safely and 4 gauge 65-70 amps, AGU would be just fine. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifIf you had to choose one or the other for a distribution block(4 gauge to two 8 gauges) what would you choose, and why?
-Lurius
Ive got a dual ANL distro block sitting in my tool box...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifI don't think they make ANL distro blocks. If they did they be ****in huge llol.
the main difference is the amperage ranges. AGU goes from 20(iirc) to 80' date=' where as ANL goes from 60 to 300 (again iirc) and it costs more. Given that 8 gauge is not capable of conducting any more than 35amps safely and 4 gauge 65-70 amps, AGU would be just fine. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif[/quote']
Wow - you go the extra mile to help out the wire retailers.
8 ga - ~50A
4 ga - ~125A
Ive got one of those streetwires fuse/ground combo blocks, and my ANL fuseholder alone is almost as big lolIve got a dual ANL distro block sitting in my tool box...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
1/0 in 2 4ga out. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
No I do installs CORRECTLY.Wow - you go the extra mile to help out the wire retailers.
8 ga - ~50A
4 ga - ~125A
