Aftermarket sub cuts out at high speeds and revs
  • 2
Asuri3
2015 Lexus is250 f sport. Had this same setup in my 2012 Audi a6 and it was perfect. Just got it installed in my Lexus and the sub just cuts out at high revs and speeds. Does anyone know what is wrong. I have searched everywhere and have not found an answer.
Are the subs using a separate amplifier? If they are, have you tried turning up the gain/input on the amplifier? Is it possible that at high revs or speeds, that the electrical system is pulling power from your headunit and diminishing the signal to your amplifier and/or your subs? Just a guess.
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
594
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
908
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
693
Asuri3
Asuri3
Chicago
huberoy123
    Apr 26, 2024
    Apr 26, 2024
