Aftermarket Stereo with Stock Amp
IFeelYourPain
I have a 94 Lincoln Continental, in which I am going to wire a Sony single din aftermarket radio, but I am having trouble with getting the right parts, since it has a stock amp.
Receiver Wiring Harness For select 1989-2000 vehicles at Crutchfield.com
^^ The above wiring harness shows 4 RCA plugs, and my aftermarket head unit only has 2 outputs for my sub, in which case I will be using my sub... so I can't use those ports.
I also found this one:
HARNESS METRA 70-5514 Ford Into Car Wire Harness Sadio wiring harness AMP BYPASS SYSTEM. This product is for a car radio installations allows the installer to wire an aftermarket radio into a car without cutting and splicing the factory radio harness
In which it doesn't use RCA jacks. I am just not sure on which to use, which will sound better, ect.
Now in my Miata I used this:
Scosche OEM Amplifier Adapter 1993-up Mazda at Crutchfield.com
I don't know if there is anything similar, but any info would be nice.
easiest way is to use the 1st one w/ "y" adapters the output on the rear of h/u if selectable (rear/sw) so make sure on rear/full range and you'll be fine
the second is a three piece harness the front two will connect your h/u to car and the last piece will simply bypass the factory amp by "jumping" it i usually use a standard harness and just bypass the amp myself but if you want "plug and play" both of those will work but #2 will be easier and can be returned to stock easier
So it seems you need front and rear preouts on the HU - if you don't have those you can use a pair of LOC's off the HU speaker outputs. Hope you have room in that dash...
jesus, this is not that difficult.
Get this: Scosche OEM Amplifier Adapter 1993-up Mazda at Crutchfield.com
Use the speaker level outputs from the HU, attach them to the input end of the above adapter, then connect the outputs from that adapter to the metra harness into the vehicle. Then, you have your signal. Also be sure to connect the remote wires to not only your amp, but also the metra harness so the oem amp turns on.
I've already searched for it, I can't find one... =[
EDIT: Ohhhh I think I was mistaking the Scosche part with the wiring harness. So I just use the OEM Amplifier adapter I already have and install it with wiring harness for my Lincoln, right?
IFeelYourPain
IFeelYourPain
Tennessee
2007rustanggt
