Aeroports or slots?
I like areo's in boxes but it would be nice to know how big he can go. If he has like 8ft of useable space he could go very big with the aeros.
He he has the space available, I would just go with slot port in most cases. He will likely have an issue with the port length if he goes with a large amount of port area. That has always been a huge issue with them. Most enclosures are never more then 15-20 deep so that is rather limiting in port length.
you have 3.68 cubes to work with. using a single 6" aero 22" long will net you 3.09 cubes for your subs and give you 30.55hz tuning. add in the aero flares and you should be at or just below 30hz.
Matt
oh, and i used .2 cubes as sub displacment. forgot to take into account bracing. so you may end up with slightly less than 3 cubes and have to add an inch to the aero. but im sure someone will factor all that in.
Matt
Yeah i'm gonna use Precision Port too for my application, if that's what i end up deciding.
Matt, My sub displacement is 0.14. is that for the single chamber and port on the side running the long way? did you use torres?
I was hoping to get port and subs facing back, unless it wont make a difference?
Omega, The 35" is total, because i need to fit it in my trunk....lol so there is room on the sides for sure but not enough to actually build with.
yea i used torres. subs back port side. single chamber for seperate chamber just cut your width in half and use that measurement. give me a sec and ill figure it.
Matt
i dont see how you can use an aero if you want seperate chambers. usnig a 4" aero you need like 20" of port length. yu could make it an "L" aero, but id just make it one enclosure and use a 6" aero.
Matt
EDIT, im guessing the sub displacment is .14 PER sub?
Matt
N9ne Millahhh
N9ne Millahhh
Cedar Rapids, Iowa
pro-rabbit
