btlking 10+ year member Registered User 2,789 0 Uranus Feb 19, 2007 #1 if a box is 12 inches high 30 inches wide and 14 inches deep what size aero port do i need to tune it to 50 hz and 38 hz Click to read more...
Abel 10+ year member CarAudio.com Veteran 2,190 3 Chicago,Il. Feb 19, 2007 #2 is that the internal size?
OP btlking 10+ year member Registered User 2,789 0 Uranus Feb 19, 2007 Thread Starter #3 those are the max dimensions the aeroports will be external
Abel 10+ year member CarAudio.com Veteran 2,190 3 Chicago,Il. Feb 19, 2007 #4 for 50hz and 1 port you need 7.25 inch of straight lenght, and for 38hz w/ 1 port you need 16 inch's of straight lenght
OP btlking 10+ year member Registered User 2,789 0 Uranus Feb 19, 2007 Thread Starter #5 of a 6 inch port?
Abel 10+ year member CarAudio.com Veteran 2,190 3 Chicago,Il. Feb 19, 2007 #6 oh //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif what size port and how many did you want to use? For some reason i had 6" porrts on my mind lol
OP btlking 10+ year member Registered User 2,789 0 Uranus Feb 19, 2007 Thread Starter #7 6 inch works
Abel 10+ year member CarAudio.com Veteran 2,190 3 Chicago,Il. Feb 19, 2007 #8 ok then thats the lenghts you need //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
OP btlking 10+ year member Registered User 2,789 0 Uranus Feb 19, 2007 Thread Starter #9 do you know where i could purchase some?
j3bus2k3 5,000+ posts Si vis pacem, para bellum 6,712 36 St. Pete, FL Feb 19, 2007 #10 psp's flared ports or just 6" PVC? http://www.thrilleraudio.com/searchresult.aspx?CategoryID=12 has psp-ins ports. Just remember that with those kits, you need to trim off 5" of the length and cut the tube to that new number and then add the flares...
2loud4u 10+ year member Nothing to see here 2,250 0 canada Feb 19, 2007 #11 for 50hz and 1 port you need 7.25 inch of straight lenght, and for 38hz w/ 1 port you need 16 inch's of straight lenght Click to expand... psp's calculator disagrees
j3bus2k3 5,000+ posts Si vis pacem, para bellum 6,712 36 St. Pete, FL Feb 19, 2007 #12 ^Hes right. PSP says for 2.165ft^3 (as per your max dimensions): 50Hz - 9.66" straight; 10.66" flared 38Hz - 19.93" straight; 20.93" flared
