!!!Aeroport LOVERS!!!
this wont be an flatwall it will be clamshelled
I remember when MD built their blazer. They had a clamshell w/ aeroports and it sucked. They filled in the ports and it hit hard.
You have to remember that a clamshell is actually a type of 4th order bandpass. Once you start porting those enclosures, it's basically going to act like a 6th order. Once you go there it is extremely tricky to get right.
hmmm.... what do u suggest? i mean i def want the 12's to be ported maybe design it like wills truck? instead of how frankies car is?
Now, in Potts case.....
He built a solid shell, fired the subs down and the aeroports back. That install was sick as all hell... 53's under 30hz w/ only 1 2500D and 2 typeR 12's.
Keep in mind, he tore it out and tried to duplicate it the following year only to fail.
i was thinking just like that but instead of the slots i would use aeros
I thought he tore that out?
I'm not saying don't do it, just don't plan on it working out of the box.... stuff like that is tricky.
Here's mine... did a 53 @ 26-29hz and did a mean hairtrick.
4 15's and 2 zx2500.1's @ 2ohm
u used aeros in that box too right?
Nope, the boxes were slot ported at the bottom rear. I was going to rebuild w/ aero's but ended up with a regular wall. All 4 subs on the passenger side and a narrow drivers side port.
156@41 hz and an even nastier hair trick.
Then I tore that out and did 3 subs with a bottom port the week before finals = fail. 153@46hz:furious:
The first thing I did was 4 10's in that same shell the 15's are in except I used aeroports. The note was higher(49hz) but it was still pretty nasty. 155 w/ an opti 4000d.
so what do u think i should do for what im going for? 4th order,ported like wills truck or something else. all i really want is for my truck to be impressive and pull mean hairtricks thats why im going with so much cone area and power.
tooloud4tv
tooloud4tv
Georgia
tooloud4tv
NorthFramingham
    Jun 30, 2026
