aero ports
  • 5
12 inch aero port is 113"
10 inch 78.5"
8 inch is 50.24 "
6 inch is 28.26"
if you want 180" aero port your gonna have to use multiple pipes that sum together to get you close to 180
If your buying ports they should have the area listed
Ok this is my first time trying to build a box using aero ports my subs say 16 cube inches per cube ft so I want to get it right,i know how to get the.
Tuning right just want to get cubec ft right.
dude post your equipment, what are you using and your box measurements, ill help you out!!!
for 12cuft net (means after port and sub displacement discounted from entire volume)
Yeah, run a single 18" or a pair of 15"s with that little area. We just rammed a pair of 15"s in the trunk of an Avenger and it's just pretty disappointing when you don't have the room you need. My 10"s in a proper box outperformed the 15"s...
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
bass head 4-15s
leakesville ms
bass head 4-15s
    May 24, 2024
    May 23, 2024
