Aero port ?
  • 7
You can do 4in i was going to run 4 on my btl i was just scared cause it wasn't enof port area.
2 6" ports are the same as 4 4"s right? If 4 4"s weren't enough for yours will it be enough for me? Would 6 4"s work? Too much or not enough?
personally I use 1 4" aero per 1.5 cu.ft. so that would come to 4 for your enclosure. 2 6"s would be closer to optimal port area tho. 1 6" has more area than 2 4"s
Would 5 4"s be better than 4 then?
4 4" is just barely enough, imo. But, I'm the type that likes to run a lot of port //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
903
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
610
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
767
1ndatrunk
Can I live?
1ndatrunk
Close
1ndatrunk
    Apr 28, 2024
    Apr 28, 2024
