Advice needed on a 1 ohm 1000w amp for around $200-$250..Pioneer GM-D9601 ?
difference is a refurb and 90 day warranty ,and a bnib with a 1 year warranty .the vfl 75.1 actually puts out 1000 rms at 14.4 volts
Our Refurbs are 1 YEAR WARRANTY BTW. just saying. Reading = Winning
the SAE-1200DV2 is good for 1300-1500 in the 12V range, 14.4 good for 1700.
a lot of good choices //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i have a used cadence dayton dca1000.1 120 shipped //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Amazon.com: Cadence DCA1000, 1-Channel Class D Amplifier, Daytona Series, 1x 375 Watt RMS @ 4 Ohm Mono: Car Electronics
1000rms at 12v's
Audio Technix 1200 1 Amp Amplifier 1200W RMS 2400W Max Class D 1 Ohm Stable | eBay
great amp rated at 12v's will do 1500 at 14 easilly
Audio Technix 800 1 Amp Amplifier 800W RMS 2000W Max Class D 1 Ohm Stable | eBay
will do 1000rms easily at 14v's also as you see has 120 amps of fusing same as sundown audioque etc.
Cadence Old Skool Ultrashock A7 HC 1200WRMS Mono Sub Amp VGC 013034009987 | eBay
if used best amp on the list made in the usa by zed audio an old school cheater amp that puts out 1400rms plus and very effecient.
the american bass is also a great amp that mylows10 is selling
Mmats E1000 1D | eBay
this si the amp i would get built in the usa mmats legendary amps
That's good to know Chris. I was told a fees tears back it was only 90 days like most refurbs. My bad sorry man
The Refurbish work we do is far beyond what the other companies do. We actually go over what's there and rebuild entire sections of the amps, the others either put a whole new board in (which may end up with same factory failures as the original did, because something need attention, may just be a solder joint) or they simply only replace single parts that are bad and call it good and they only offer 90 days. That's why refurbs get such a bad rep. If it's done right, technically it's better than new, because any good tech will go over the whole board looking for weak/missing/bad solder joints etc, the manufacturer repair shops that slap new boards in, do not do that, and the el-cheapo repair shops that do the super cheap 90 day refurbs just replace 1 or 2 bad parts and put it back up for sale.
hodgesdodges
Bass lover
hodgesdodges
Linton Indiana
FireGS
