Advice for false wall with current setup
Myster
I am trying to figure out how to impliment a false wall with the current enclosure and HAVE NO IDEA WHAT TO DO! Would like the cleanest possbile setup that will go with a false floor (in the works).
-thanks for the help and time
Looks like your trunk curves. For the wall I would use a piece of thin plexi or plastic sheeting covered with carpet ofcourse. As far as the false floor is concerned, do you need access to the spare?
False floor I am thinking about using hinges over the amp rack and battery box......
Living in Arizona would a plastic wall hold up? I was thinking about using a sheet of thin wood with the cut out of the enclosure but what not sure if I wanted it to go infront of the enclosure or go around.....
thats what I did in my KIA. False floor with the amps attached to a board. That board is hinged. The plexi should be thin enough to bend. It may need a bit of pursuading with a heat gun to make a nice contour. Once you have it shaped the heat shouldnt affect it at all. A couple of heavy duty velcro squares ought to hold it in place nicely.
Myster
Myster
Scottsdale,AZ
docutech
