Advice between New MB Quart FX1.600 vs Used Alpine MRP-M500?
realdragonluv
Good morning. I've been reading the forums for a few days now and finally joined. I was wondering what are the thoughts between getting one of the following:
Added Boston Acoustic gt-2125 $123
RMS Power Rating(CEA-2006-A):
Bridged, 4 ohms: 400 watts x 1 chan.
Bridged, 2 ohms: 600 watts x 1 chan.
RMS Power Rating(12V):
Bridged, 2 ohms: 475 watts x 1 chan
New MB Quart FX1.600 (around $100 with 1 yr warranty, $114 with 3 year warranty)
Class AB
RMS Power Rating:
4 ohms: 300 watts x 1 chan.
Signal to noise ratio: 95dB
Variable low-pass filter: 40-300 Hz
Subsonic filter: 10-40 Hz
Frequency response: 10-300 Hz
Used Alpine MRP-M500 (History unknown. $101 but has a 2 year warranty for that price)
Class-D (Digital) Amplifier Type
RMS Power at 4 ohms: 300W x 1 (1% THD)
RMS Power at 2 ohms: 500W x 1
Signal to Noise: 100dBA
Adjustable low-pass filter (50-200Hz, 24 dB/octave)
Subsonic Filter (24 dB at 15 Hz)
Frequency Response: 20 -200Hz (200Hz/-3dB)
The setup this will be used on:
DDX-418 head unit
One Subwoofer: Infinity 1260w in a single sealed enclosure RMS: 300 watts Impedance: Single 4 Ohm
Could switch to a 1262W if it would be better/beneficial. Specs are the same except for Dual VC instead of single.
Any feedback/suggestions are greatly appreciated. I've only been given about $100 budget for the amp so those two seem to be decent. I'm only looking to fill in the low end, nothing more.
I don't have a direct experience with either of these two amplifiers, but my gut feeling is that Alpine, when new, is a better built, better executed product. All of recent MB Quart products have obvious cost cutting in them, and FX is their lowest end line. Bump your budget a little and look for something more solid. I'd recommend to run a PPI Phantom P600.2 bridged. Onlinecarstereo.com has it for $140 right now. I have a 4-channel version of this. It runs cool and takes lots of abuse. Don't worry about fuse rating. Since you will hopefully run only 300watts to the subwoofer (setting gain by DMM might be a good idea), the amplifier will need less current than what the fuse rating may suggest.
Another amplifier you can try is Boston Acoustics GT-2125, which should be good for about 400watts bridged. The GT line of amplifiers was clean enough to power full range reference quality speakers, not just subwoofers, and it was somewhat pricey. Now BA is exiting car market, and some vendors are clearing old inventory at good prices (this one is for about $125 on Sonicelectronix). The only issue is that it's a Class A/B design, so it needs good airflow about it. In my book, P600.2 is the winner though. Being only $15 more expensive, it's very small and efficient.
Well certainly some food for thought. I had looked at the Boston Acoustics but I saw it didn't have the subsonic filter. It's been years since I had a sub and amp so this is all new again so I don't know how good/important that feature is.
I would certainly like to keep it in the 100-120ish range so any other suggestions would be appreciated.
The next question would be am I better off getting the Dual Voice Coil Infinity and have the gain all the way down running the amp at 2 ohm or keep the single at 4 ohm? (assuming the amp I get in the end is 2-Ohm stable)
To answer the used warranty question on the Alpine, it would be purchased through a third party vendor similar to SquareTrade.
Thanks in advance, I've been out of this for too long...
Well from the replies and further research on these boards I'm probably leaning towards going with the Boston Acoustics GT-2125 since it's available for around $123.
Bridged, 2 ohms: 475 watts x 1 chan.
Now is it better to be paired with the DVC Infinity 1262w bringing it down to 2 ohm load or the single VC 1260w 4 ohm load? They are both rated 300 RMS and will still be in a sealed 1.25 box
Thanks again for the help so far.
Well I finally made the purchase and it's nothing like I originally had here.
I ended up going with the Boston Acoustics GT-2125 amp and the Boston Acoustics G112PS pre-loaded SUB. I just couldn't pass up Boston Acoustics at those prices and thanks to everyone's suggestions.
I was thinking of doing a step by step amp install post with pictures for an 2008 Buick Lacrosse. Is this something that is supported on caraudio.com? I've done something similar when I installed the head unit in my wifes car over here on a 2010 Dodge Caravan SXT: A "How To" install aftermarket radio ***Warning very picture heavy***
anything to help the noob idiots that think SS filters are for pussies is welcomed here.
realdragonluv
realdragonluv
United States
quackhead
