Advances/Disadvantages of a Dual battery relay
  • 1
nstillmatic
I have dual batteries; yellowtop in the front and a Kinetik HC2000 in the rear. My priority is keeping the kinetik decently charged. I bought a PAC 200amp relay but never installed it, would it be beneficial or would the voltage drop from using a relay make it worse?
My distribution block has a voltage reader, and it idles above 12v and is about 13.5 to 14v with car running but that's with the two battery+ wired together obviously.
381
597
976
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
922
nstillmatic
nstillmatic
Cleveland, OH
nstillmatic
