emilimo701
This is a multi-part question.
I have decided that I will invest in a Rockford Fosgate T115D4 and power it with my Infinity 1600a (600 watts @ 2 ohms).
before I buy it, I wanted to make sure I could build an enclosure that would fit in my Suby wagon. I have plenty of space in back, but you never know.
In my effort to learn more about subwoofers, I have tried my best to understand the Thiele/Small parameters and their relationship (or lack thereof) to a sub's sound output.
My first question, which has less to do with the T115D4 and more to do with woofers in general, is:
1) To what extent does QTS (and Vas) dictate what the ideal enclosure size should be?
I have used a few enclosure calculators: a couple online resources, and WinISD. All calculators show that there should be a significant difference between box volume between manufacturer's woofers that have 2-ohm impedance vs 4-ohm impedance. Yet all of these manufacturers recommend the exact same box volumes for either sub (with the lone exception of JL Audio).
For example, the T115D2 vs the T115D4:
T115D2: Qts -- .43, Fs -- 26Hz
T115D4: Qts -- .51, Fs -- 27Hz
Rockford Fosgate recommends a sealed box size of 2.0-2.5 cubic feet for either woofer. But according to this calculator, the "ideal" box volume (with Qtc at .707) for the D2 is 1.85 cubic feet, and as for the D4... 3.42 cubic feet! Not only are both volumes outside of the recommended range, but they are on opposite sides! I got about the exact same results for 3 or 4 other manufacturers of woofers within the same RMS/price range. Same thing for ported boxes.
Anyway, if I get the T115D4, I plan on putting it in a ported box, tuned to somewhere between 30 and 32 Hz in a slot-ported box. This is what Rockford Fosgate recommends for slot-ported enclosures for their 15" Power-series subs:
So my second question, in less words, is...
2) What gives?
First of all, I did the calculations half a dozen times. The internal volume is 3.35 cubic feet, not 3.25 which is what they printed. Also, the port length they list is 22.5 inches. But that length does not include the corner -- at all. I'm not a physicist, but i'm sure the corner makes a difference in the tuning frequency.
I used this calculator and gave RF the benefit of the doubt, entering 3.25 as the box volume. Lo and behold, a port length of 22.5 inches yields a tuning frequency just under 38Hz, just as specified in the image above. So does the corner really not affect the tuning, or are these calculators simply too naive the accurately predict performance?
Lastly, what would you (directed to people with experience in this area) recommend for box design for the T115D4? Definitely go higher than 3.25 cubic feet (RF dictates 2.25-3.25 for both the D2 and D4)? Definitely tune it lower? I sketched up a mod to RF's design above; which entails decreasing the port width from 3 inches to 2.75 (lowering the tuning frequency), increasing the box depth by a few inches (which would simultaneously increase box size and lower the tuning due to extending the port), and decreasing the box width by an inch or so (so that the volume isn't TOO great). Would this be a good solution?
Thanks for any responses! This is my first post here, and i really did try to do as much research on my own in order to not ask obvious questions, so take it easy on me. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
EDIT:
I should probably specify my goals. At first, I was dead-set on SQ, SQ, SQ. But after a year of driving around, I realize that I use my woofer mainly for rap. And I really want to get those low-lows that i'm not getting from my Kenwood in its sealed box. So that's why I'm going ported. And from what I read, all those "ported boxes aren't for SQ and don't sound as good" rumors are, well, rumors. I'm sure a ported sub would do just fine if I decided to pop in a Pat Metheney or Miles Davis cd. Hitting those low-lows when listening to Flo-Rida or Young Jeezy and getting a flat response are more important than SPL and efficiency. After all, 600 watts in a ported enclosure will give me all the SPL I need. So that's why I'm planning on going with a bigger box and tuning it low.
2) What gives?
EDIT:
