Adire Shiva's?
mulisharider10
Low Co. Motives
Well, i know that adire makes a pretty mean woofer called the brahma. I know that a jl 12w3v2 sub is a really good sub. Does the shiva, in any way, compare to what the w3 can put out. I dont care about the woofers lives, im talking stait output. Which one sounds better in a nice 1cu.ft. box off the recommended wattage?
wow howd u get that sub for $75? anyway i have 2 shivas each in a cube sealed off a jbl 600.1 my buddy has 2 w3v2 12's in a cube each sealed off a jl 500/1. we both feel mine have better output and sq. id take the shiva over a w3 anyday.
I had a shiva in my car in both 1 and 2 cubes and 1 didn't sound very good but 2 was AWSOME. Definately 2-2.5 cubes sealed will make the shiva sound good....1 cube you might be better off going with the jl but I don't know I've only heard w3v2's in bigger sealed boxes.
Also, in a Mazda 626, will one shiva be enough? I don't mind the cost, but if each one needs 2.5 cubes sealed, I do mind the box size. I listen to everything but jazz, classical, and country. I like it to pound enough to shake the mirror a little (as a point of reference), but I don't need ear-splitting power.
If I do decide to go with only one sub, what can beat the shiva all-around without exceeding $250? I'm mostly interested in sq, but need enough loudness to bump. I have a feeling I won't need more than one shiva, but I haven't heard much, so let me know.
what do u think they would sound like in a truck box?
How large of an enclosure?
I've ran 1, 1.5, 1.75, 2, and 2.5 cubes sealed per driver so far. The best results for my truck (not a truck box, this is a center console) was 1.75ft^3 sealed per driver - sounded the best to my ears - which shouldn't mean much to you.
Single Shiva in a regular cab truck should be plenty for most.
- Steve
You don't necessarily need 2.5 cubes sealed per driver ... as I mentioned before, I've ran two in that volume. The results weren't optimal, at least to me, so I bumped it up a little bit. I'd look to give up around 4ft^3 - 5ft^3. Tempest an option for you?
- Steve
Yeah, I'm considering a Tempest. I can fit it in vertically. I know it will be louder and hit lower, but will it loose any sq over the shiva? Will it loose any upper-bass over the shiva? Because I like upper-bass that punches you rather than low-bass that just rattles everything. I've listened to Three 6 Mafia and Lil Jon and didn't like that type of bass at all. I like the bass in songs from Michael Jackson, eminem, and some nelly. Varying frequencies with some punch. As long as the tempest doesn't loose any upper-bass, I'm cool. That's the only thing that worries me about the tempest.
Tempests rock. I've done a lot of installs with them and they sound great. And the reason I was saying 2-2.5 cubes for the shiva is because around 2.5 cubes what you need for a .707 QTC alignment, which is preferable to most people. 2 cubes would sound good too but the smaller you go the more low end your sacrificing and the less even the frequency response will be. If your gunna go with a tempest it likes a 4.5 cubes box sealed, but would still sound good as low as 2.5 or 3.
mulisharider10
Low Co. Motives
mulisharider10
San Diego, Ca
I want SExxx
